How do I compare different versions of lvproj in ClearCase?
I am using ClearCase as source control for Labview.  I created a development branch off of the mainline.  When an attempt was made to merge the content back to the mainline there was a complaint that a manual merge would be necessary because the lvproj file had changed after the branch was created.  When I look at the version tree I can see that a change was made to the lvproj file after the branch was created.  The change was made by a developer no longer with the company.  Is there a way to compare the two lvproj files to see what the differences are?
(2,331 Views)
Project files are just text files, so you can use any text based compariosn tool to gt an idea of where the differences lie.
(2,324 Views)
