append control image
I Have a problem with the append control image to report VI. I Have a Array of clusters that contain 3 numeric indicators and 2 vertical pointer slides. When i try to append this iamge to a report, the picture thats appended downt contain the whole control, and has some weird artefacts. With other controls the append control image to report vi works fine.. Is this a bugin LV 8.0 or am i doing something wrong?
Thnx
Bart
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
Message 1 of 8
(4,598 Views)
There is a bug in LabVIEW 8.0 with appending cluster images to reports.  I believe it's fixed in 8.2.
-D
Message 2 of 8
(4,587 Views)
then i have a problem... but i can do it with other clusters....thats working fine.
Promedes and DSM
Message 3 of 8
(4,583 Views)
Can you post a very simple example VI that demonstrates the problem?
-D
Message 4 of 8
(4,579 Views)
Ok here is an example, the cluster is being appended in the subvi
Promedes and DSM
Message 5 of 8
(4,563 Views)
Thanks for posting the sample VI.  This problem is due to the cluster image problem I previously mentioned.  I can append your cluster image to a report in LabVIEW 7.1 and LabVIEW 8.2 just fine, but with LabVIEW 8.0 part of the control is missing.  So as I previously mentioned, this bug is present only in LabVIEW 8.0.x, and is fixed in LabVIEW 8.2.
-D
Message 6 of 8
(4,553 Views)
i created a work around bij appending the frontpanel image to a html report. Is this also possible with a word report? When i try this i get an error that this action isnt compatible with this kind of report?
Thnx
Promedes and DSM
Message 7 of 8
(4,541 Views)
Are you using the Append Front Panel Image to Report VI?  If so, you shouldn't see any problems...this VI should work with all report types.  In fact, we use this VI when appending "VI Documentation" to a report generated with the Report Express VI.  Are you using a different approach to append the front panel image to the report?
Once again, if you're still having trouble, please post a simple example VI that demonstrates the issue so I can try it out.
-D
Message 8 of 8
(4,535 Views)
