antenna rotator - ARSWIN communicating with labview?
hi folks
i want to use labview to control, send commands to a program called ARSWIN, this program is used with hardware called ARS , (antenna rotator system). i have ARSWIN  installed, is there a way to use labview with it?
the ARS  h/w is used to control an antenna rotator attached and i would like to use labview to control the movements (via the ARSWIN program).
any help is much appreciated.
regards
Eric
(3,735 Views)
I googled ARSWIN and found some references to it being a DDE server. Though an obsolete interface long abandoned by Microsoft, there are still DDE functions and a couple of examples that ship with LabVIEW. The functions are no longer on the palette but can be found in vi.lib\Platform\dde.llb.
(3,730 Views)
hi Dennis,.
is it a DDE API protocol. the guy selling the product told me that. i have no idea thou. he also mentioned to use windows messaging to comm with ARSWin..?
ps: got that power consumption up and running! thanks for your help. now i need to measure radiation (rf) with a spectrum analyzer.....!
Eric
(3,719 Views)
DDE was something invented by Microsoft for inter-process communication. As I said, it's been obsolete for a long while. I found this example of DDE and ARSWIN. The DDE_App and DDE_Topic would be done by the LabVIEW DDE Open Conversation, the DDE_Item by DDE Srv Item, and the DDE_Send by the DDE Execute function. There's an app note here [broken link removed] that might help.
(3,714 Views)
Dennis,
thanks for that, must be possible to do what  i want so? need to go over this
regards
Eric
(3,703 Views)
