Manipulating a Binary File.
I am looking in a binary file that has many blocks of data in this file. There are several headers in the file that don't necessarily start at the top. I need to find where 3,61, and 8000 all happen sequentially. This is the header that starts the block of data that I want to look at. I did a type cast because of the Little Endian Big Endian issue. The data is a one dimensional array of Unsigned 16 bits(two 8 bit words). I would like to put it into a spreadsheet. Thanks in advance.
(2,953 Views)
I may have misunderstood your statement, but it sounds like you're saying that the file can contain multiple data chunks, each of which is preceded by the header 3,61,8000. If so, you can use something like the attached VI to extract out each data chunk and create a concatenated array of data with which you can do whatever you need. It's crude, and I didn't spend a lot of time trying for a really elegant solution, but you get the general idea. The input is the array that is the array of U16 that is the file you read.
(2,933 Views)
