animated dots
Hello Everyone!
I would like to make my project a bit more fancy, so I would like to make a little animation on the status string indicator.
Please see the attached subVI, I have also attached a main calling VI, so you can see how I want to use this. I would like to ask your opinion about my approach. Can I make it better? Also, I do not like the coercing red dot on the input of the subVI.
Thanks very much for advice!
Best Regards,
(2,914 Views)
Accepted by Blokk
Firstly to remove coercion dot.
Create a string reference control,copy and replace with ctl refnum in subvi and remove 'to variant' vi.
Second.. Use classic controls.
Bijay
(2,904 Views)
Thanks, no more coercing dot 🙂
I guess using classic controls in subVIs instead of modern controls make better downward compatibility? Is this the reason?
(2,899 Views)
