angle between two lines in arc minutes in labview
Is there any method or VI in LabVIEW using which I could calculate angle between two lines in arc minutes?
(2,369 Views)
Hi priya,
Do you ask for the basic (trigonometry) math to calculate an angle between two lines/vectors?
Or do you ask how to convert from rad to degrees/minutes/seconds?
(2,368 Views)
Calculate the angle in rad and multiply by 3437.747
Qestit Systems
Certified-LabVIEW-Developer
(2,326 Views)
If you want the angle between lines, how are the lines defined?
It doesn't really matter from the math point of view, but the solution in code will be different.
Consider posting a VI with the controls and indicators you'd like...
(2,321 Views)
Calculate the angle in arcseconds and divide by 60 😁.
If conversion is the problem: Minute and second of arc - Wikipedia
(2,318 Views)
Accepted by topic author priya9129
there's this thread to which I'd like to point you:
https://forums.ni.com/t5/LabVIEW/angles-between-lines/td-p/1047570/page/2
(2,317 Views)
