analog voltage input to analog current output
how do i wire connections using myDAQ to analog output current ??
(3,293 Views)
Hi green,
- There is no "analog output" in your snippet. You need to create one before you can wire it.
- Once you have your AO DAQmx task created you can use wires to wire it - as you already did with AI channel(s)…
(3,264 Views)
