analog output dc offset
When I use the shipping example:
"Cont Gen Voltage Wmf-Ext Clk.vi" I get the waveform out on the Analog Channel no problem.  When I stop the vi there is always a 3 VDC level on my output channel.  Its not there until after I stop the waveform generation.
Happens w any AO channel.
Labview 2009
PXI6723
(3,328 Views)
That sounds right.  The channel will hold the final value writen to it until it is reset.  The Arbitrary Waveform Generators do the same thing.
(3,317 Views)
Thanks...so how do you reset??
(3,312 Views)
more...
..in that particular example??
(3,311 Views)
Accepted by topic author clint100
First, I would use the DAQmx Stop Task to stop the acquisition.  If it isn't reset from that, write an acutal 0 to all of the channels.  Both of these should be done before the task is cleared.
(3,306 Views)
