Latitude & Longitude string to number through type cast
In my application i am saving the data ( 78°20.54 E )coming from gps in tdms format in the pc.
There are many such strings to save , so as this takes more memory to save the data in pc i want to type case in floating  and save .
I am typecasting But i am not able to retrive the same data 78°20.54 E while again type casting .
Please see the attached vi.
Regards
Naga
Message 1 of 47
(5,190 Views)
Take a look at the string palette, specifically:
Format into string
Scan from string
Message 2 of 47
(5,175 Views)
You can't simply typecast a string like "78°20.54 E" directly to a floating point number. That makes no sense. What is the degree symbol supposed to be type-cast to? What is the space supposed to be typecast to?
If your intent is to reduce the space storage requirement, then you need to convert the string to an appropriate coordinate system. I would suggest doing some reading on latitude/longitude coordinate systems.
Message 3 of 47
(5,159 Views)
I don't see any need to change the coordinate system. What would he gain? All he has to do is convert the lat/long values to decimal degrees and store.
Message 4 of 47
(5,151 Views)
I was referring to something that did not involve characters like a degree symbol, spaces, and N, S, E, W. In other words, something completely numeric. Perhaps conveting to decimal degrees is sufficient. I don't know. The question posted by the user was why it didn't work. And the answer is that it makes no sense to try what the user was trying to do in the first place.
Message 5 of 47
(5,143 Views)
Actually, his question was how to convert the string representation to floating point and back again.
Message 6 of 47
(5,128 Views)
Re-read the question.
Message 7 of 47
(5,124 Views)
Nagaa,
You might want to better explain exactly what you want.
Do you want "78°20.54" to be 78.3423 (I'm assuming after the ° is minutes)?  Then have E be positive and W be negative?
Message 8 of 47
(5,122 Views)
Hello every one
I just want to convert the strings like  78°20.54 E to some floating point and save this in pc so that i can save file memory . and retrive again the same value  ( 78°20.54 E ) to represent in the report generation
Message 9 of 47
(5,100 Views)
I did. He's still asking how to convert the string to float and back again.
Message 10 of 47
(5,079 Views)
