an attribute of the project was changed
attached is a zip file of the project that was upgraded from v8.2.1 to v8.5
Message 11 of 16
(1,093 Views)
Hi Jefska,
I've verified the behavior (same trouble here).  I'll be taking a closer look today and hopefully have something for you on Monday.
David_B
Message 12 of 16
(1,077 Views)
Hi David,
The HP865XX and HP8648A libraries might have something to do with the problem. Smiley Surprised
Message 13 of 16
(1,063 Views)
It looks like you are right.  If I rebuild the project with just the Utilites library (the only one without the HP dependencies) then this doesn't occur.  I have found that currently any auto-populating folder that is included in a project will result in this behavior (and R&D is working on correcting this), but it doesn't appear that your project has any auto-populating folders so this may be something new that we need to look at closer or could be something that is wrong within those HP VIs.
I'll look into this a little more tomorrow (Monday) and let you know if I find anything else that may be helpful.
David_B
Message 14 of 16
(1,040 Views)
So I think I narrowed this down to a file named HP8656B/7A Set RF On/Off.vi.  I renamed this to HP8656B7A Set RF OnOff.vi.
Here's the results (seems to take away the 'dirty dot').  We'll take a closer look at this and I'll post any additional information we run into.
Message Edited by David_B on 04-15-2008 05:07 PM
David_B
Message 15 of 16
(1,012 Views)
Thank you.  I'm surprised that a slash in the file name was causing the problem. Smiley Happy
Message 16 of 16
(1,008 Views)
