amplitude and level function
star-123
Member
Hi friends,
I use amplitude and level function. there is a state setting control in the function. What is the state setting? how can the histogram size determined?
Have nice work.
4 REPLIES 4
Knight of NI
Re: amplitude and level function
Hi number,
what's wrong with the help?
state settings specifies the method used to determine the high and low state levels of a waveform. For pulse and transition waveform measurements, state levels provide a means to identify the position in time of the waveform feature to be measured.
and
histogram size specifies the number of bins in the histogram LabVIEW uses to determine the high and low state levels of the waveform. If you select the peak method, LabVIEW ignores this input
star-123
Member
How can proper value of the histogram size determined?
Have a nice work.
Highlighted
Knight of NI
you need to know the number of bins before…
star-123
Member
How can I learn the number of bins?
