agilent 33220A
Dear all
I would like to control the function generator, Agilent 33220A using attached vi. But, it needs a subvi as bellowed. Once I tried to skip those subvi, it shows an error. I would like to generate waveform of square at 20 kHz, 20% duty cycle, amplitude of 2.5 - 3.0 V. Could I get a help? Please, refer bellowed subvi.
Loading: <instrlib>:\Agilent 33XXX Series\Public\Action-Status\Enable Output.vi
Loading: <instrlib>:\Agilent 33XXX Series\Public\Close.vi
Loading: <instrlib>:\Agilent 33XXX Series\Public\Initialize.vi
Loading: <instrlib>:\Agilent 33XXX Series\Public\Configure\Configure Standard Waveform.vi
Thank you.
(4,161 Views)
Install the driver from here to <LabVIEW> Instr.lib\
"Should be" isn't "Is" -Jay
(4,146 Views)
Thanks Jeff. I tried to install the driver as attached (hp33120a_setup). But, it dose not install the software as attched final message. Could you please help me to resolve this issue? Thank you.
(4,128 Views)
My operating system is Windows 7, 64 bit. Thanks!
(4,124 Views)
You aren't making any sense. Your first post is about the project style driver and now you are doing something with the different IVI driver.
Using a camera seems silly.
Not using the Find> Instrument Drivers seems silly as well. That would have installed the correct driver on the correct location.
(4,116 Views)
Accepted by sh78
Let's be more specific.  Use the driver found here:http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0470714759413BCCE0440003BA7CCD....  As Jeff already stated, unzip the contents to <LabVIEW>\instr.lib.
(4,082 Views)
