afg3022 burst configure vi error
Now that I have LabVIEW talking to my function generator, I seem to have found an issue with the burst configure VI:
When I switch the "Burst Mode" input from triggered to gated, the VI generates an incorrect command:
SOUR1:BURS:MODE:SOUR1
There should be a "GAT" after "MODE."
This problem occurs both in my own VI and in the Waveform Burst Example VI included with the library.
I looked closer at the offending VI, and the correct items do exist in the line select (TRIG and GAT), so I can't see what is wrong here...
Has anybody else encountered this issue?
(2,475 Views)
Problem solved:
The "Pick Line" VI to select between triggered and gated came with options "1 - Triggered" and "2 - Gated" for the line index.
The multi-line string input has lines 0 and 1, so feeding it the option "2- Gated" is wrong. This can be fixed by changing the items on the selector control to 0 and 1.
Steve
Message Edited by sbattazz on 07-11-2007 05:54 PM
(2,470 Views)
