Sound & Vibration Measurement Suite - loading WAV files
Dear members,
I was wondering if WAV files can be loaded into the Sound and Vibration measurement suite?
Of course, wav files can be converted to UFF or LSV files and then loaded into the measurement suite. The issue then becomes calibration, as there is no express VI for scaling and calibration to include as a step in the process.
I tried to perform scaling and calibration on an array of values that were converted to waveform from a wav file, but didn't achieve anything, the values read in the measurement suite after a sound analysis were still off. Does anyone have an idea how to work around this (without building a new express VI for calibration and scaling)?
Thank you
Sincerely,
MIlan
(2,937 Views)
Hi MIlan,
There are a number of examples in the Example Finder that demonstrate loading and processing a wav file using the Sound and Vibration VIs. To get to these examples follow these instructions.
1. Open LabVIEW and go to Help » Find Examples
2. Once inside browse to Toolkits and Modules » Sound and Vibration » File Input and Output
Hopefully these examples will help you get started.
Jordan D
Applications Engineering
(2,924 Views)
