adding vi's to an exciting labview driver
Hello
I am new to Labview 2019 and i have a question about adding vi's to an exciting driver.
I have downloaded a driver from the manufacturers website for a power analyzer and i have used the driver and it works fine, but i mis some functionality in the driver and i want to add that functionality.
According to the documentation i have to go to "Tool -> instrumentation -> Create instrumentation driver project". Then i can select "new driver copy an exciting driver ". Then i should be able to select an exciting driver but in the list of drivers i don't see the driver from my power analyzer that i have installed. Why not ?
Or is there a better way to a vi's to an exciting driver ?
Thanks in advance for support
(1,233 Views)
Hi Tonnie,
Does that driver come as LabVIEW project with several/lots of VIs?
Then you can simply add your own VIs to this project.
Recommendation: use some SCC tool (SourceCodeControl) to keep track of your changes!
(1,219 Views)
Hello GerdW
No the driver does not have a Labview project file. I comes with only vi's, a tree vi and dir.mnu files
kind regards
Tonnie
(1,205 Views)
Accepted by Tonnie
Hi Tonnie,
Then it is much easier: simply add your own VIs to the driver's folder.
Recommendations:
  • Place the driver VIs in its own folder in your own "Sources" directory. Use a SCC tool...
  • Create a LabVIEW project for your driver to manage the driver VI better than a simple Tree.vi can do.
  • I would also create a lvlib from the driver VIs to even better manage the driver API (by hiding internal support VIs).
  • I would delete the menu (mnu) files because I very seldomly place the device drivers in LabVIEW's  instr.lib folder...
(1,192 Views)
Hi GerdW
Thanks for your support
I will try you suggestion
kind regards
Tonnie
(1,170 Views)
@GerdW wrote:
Hi Tonnie,
Recommendations:
How exciting.  😉
Bill
CLD
(Mid-Level minion.)
(1,146 Views)
