adding time stamp with every element of an 2D array
HI
   I want to add a real time stamp with every element of a 2d array before writing to a spread sheet. My 2d array consists of amplitude and frequency.
kindly guide me how to do this.
Best Regards
RASHID
(4,915 Views)
hi rashid931,
  If your interest is adding the timestamp to every element in a 2d array,then you have to think a 2-d array of clusters,where the cluster contains element and time stamp data...
Thanks and regards,
srikrishnaNF
Srikrishna
(4,903 Views)
Hi srikrishnaNF,
        Thanks for your both the replies. Can you reply in more details with some example like your other reply.
Thanks and Regards,
Rashid
(4,895 Views)
Hi Rashid,
Did you manage to find a solution to your problem or are you still looking for examples?
We did the same thing very recently; reading multiple sensor values and writing the data to different columns in an excel spreadsheet. We created a timestamp and wrote this into it's own column, so that for each sampling interval a new row of data with timestamp would be inserted.
If you look at the picture i've attached it should give you a good idea as to what to do. Where I have used string constants in this basic example, you can replace these with whichever data type you wish to log.
Kevin
(4,847 Views)
Hi Kevin,
            Thanks a lot for your reply. Can you send me Write File.vi because it will be easy for me to see the things there.
Rashid
(4,826 Views)
Hi Kevin,
Rashid
(4,826 Views)
Accepted by Rashid931
That should be it now.
Kevin
(4,824 Views)
