adding Item to Combobox at runtime
is there a possibility to add items to a combobox at runtime?
thx
Simon
Using Labview 7.1
(3,092 Views)
right click on the combo box and select 'Create Property Node'. Right click on the property node and select 'Change to Write'. right click on the property node and select either ''Strings[ ] ' or 'Strings and Values[ ]'. You can then right click and select 'Create Constant' if you want a diagram constant to provide the values.
(3,091 Views)
