add .gif image
hi,
I tried to add an animated image (.gif) using import to a Clipboard and also using drag and drop but it doesn't work. Can some one help me?
Message 1 of 9
(3,714 Views)
Message 2 of 9
(3,710 Views)
I tried to load GIF_LV85.zip 889 KB but it's damaged.
Message 3 of 9
(3,698 Views)
Message 4 of 9
(3,692 Views)
thanks for the example but it works for .gif image that i can simply add by drag and drop but i can't add an annimated one...
Message 5 of 9
(3,653 Views)
Hi olfa_ouni,
can you please explain a bit more? What do you try to do? What do you expect?
Mike
Message 6 of 9
(3,647 Views)
I try to add the button in the attachments to my front pannel.
Message 7 of 9
(3,632 Views)
Hi olfa_ouni,
sorry, but it would be great if you can explain a bit more. If you only need it on your FP, then you can add it with drag and drop. Do you want to use it as a button or what do you try to do?
Mike
Message 8 of 9
(3,627 Views)
If you want to replace the existing control then you have to go to edit-->customize control and replace the existing boolean control with your image.
Message 9 of 9
(3,622 Views)
