How do i get the font of the tip strip?
how do i get the font of the tip strip.
I load the tip strips of all panel obejects by an external text file.
The external text file (fi edit by notepad) has a font that is not the same as the tip strip.
The tip strip looks not nice text is not in line.
Example:
::: is the object label with the tip strip info behind.
:::StopOnFailRB
Stop when a fail or pass is detected.
LSL on USL on:    LSL < result > USL      FAIL outside Spec Limits
LSL on USL off:    LSL > result                FAIL Lower Spec Limit
LSL off USL on:              result > USL      FAIL Upper Side Limit
LSL off USL off: LSL =< result =< USL    PASS between Limits
Kind regards, Bernard Arts
(3,518 Views)
I tried, but couldn't find it.
Jim
(3,492 Views)
Someone give this answer:
    "I have been looking on NI's website, the tip strip seems to be a function of Windows"
If it is a fucntion of Windows how can i get the Font?
(3,473 Views)
Hope this link will give you some information about the Tip Strips in LV
http://lavag.org/topic/8319-tip-strip/
(3,450 Views)
This "http://lavag.org/topic/8319-tip-strip/ " was the webside were i get the answer from
(i visit already before you suggest).
So that is not new to me and doesn't help me.
Kind regards Bernard Arts
(3,416 Views)
Accepted by topic author Ben_Arts
The tip strip setting is a function of the "ToolTip" setting in Windows Appearance settings available by Control Panel\Appearance and Personalization\
Casper
(3,386 Views)
