adapt code on CRIO 9068
Hi all,
   i have a code working (supposed) to work on NI 901x and 900x plate-forms. i want to adapt it to work on NI 9068.
   i can connect to my CRIO 9068 but the local chassis is stil named (NI 9101), i can change it  to CRIO 9068 but the compilation failed when compiling the code (which is a simple use of NI 9870).
   what i can do to adapt my code to CRIO 9068?
SASA.
(3,304 Views)
Hi Sasa,
so you try to adapt an older LV project for your new chassis?
You need to re-assign all hardware related items in the project, starting from chassis and including shared variables & ScanEngine items…
(3,298 Views)
Accepted by SASA1
I would recommend creating the new target in your project and then drag everyingthing from the old cRIO target to the new.  Then delete the old target.  You may been to recreate your build specs.
(3,290 Views)
Hi all,
   i think that it is much more complicated, my old code was implemented ino SBRIO !!!
   but now i'm able to communicate at least with one instrument, still the other
SASA
(3,255 Views)
