actvaite licene
 Problem:
I downloaded and installed LabVIEW 8.5.1 for use in my FIRST competition, but Labview does not accept my activation code.
I place the file in ..\National Instruments\Shared\License Manager\Licenses.I read all http://decibel.ni.com/content/message/2606#1663It was suggested that I post my question here. The link above details my issues with the activation of LabView. thanks for any help you can offer!Monetor teacher team 1946Mohamed Abu Fawdah
(4,604 Views)
Hi  Mohammed,
Thanks for the post and I hope your well today.
I would recommend using NI License Manager. When you open this, and look at the left hand tree - the LabVIEw 8.5.1 will have a coloured square, green for activiated, red for expired license etc. If you then  right-click and select activate , it will start the wizard. You can then enter your serial number if you have one and it should take you through the steps. If this errors, you need to double check the serial number and the computer ID you entered.
If you could please also confirm you mean NI License manager and not Volume Licesnse Manager...
Kind Regards,
James.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,560 Views)
Hi
I hadserial number    for Product: LabVIEW Full Development System  Version: 8.5,
when I updat to 8.5.1 I lost the Activation .
is there any who so I can get    serial number   for team FRC 2009 or activate because the time is runing I need to study the programe to teach my kids at he team.
thank you
(4,548 Views)
When you do a Help>About LabVIEW, do you have the serial number listed in the popup?
(4,544 Views)
Accepted by MESHKA
Meshka,
Since the Programming and Activation of FIRST software is different from our traditional software, we ask that all FIRST questions be made on the First community at http://decibel.ni.com/content/community/first?view=discussions
As for your specific question, take a look at http://decibel.ni.com/content/docs/DOC-2435 a lot of people seem to be having a hard time renaming the .txt to .lic extension.  If you have more problems, the FIRST forums should be able to help you out, as we have engineers trained on FIRST equipment who monitor those forums Smiley Happy
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(4,532 Views)
Hi Rob and Meshka,
Thanks Rob for the great post - I was no aware how licensing worked for the First stuff.
Meshka, I hope this helps to resolve your issue and I wish you luck with your project.
Kind Regards
James Hillman
(4,519 Views)
thank you
Problem solved as you said
meshka
team1946
(4,507 Views)
