activex
Hi guys,
I've done a small vi that prints a pdf-file through activex. It seemed to work fine (and showed to be quite similar to a posted vi on the forums), until i called it from another vi, that is.
I got the error "Must be a user interface", which i set through vi-properties.
I got a empty window hanging which didn't close until labview was closed, which seemed to be a timing issue, so i've added a 3 sec delay to be sure acrobats activex-control is loaded before closing it.
Now, the real problem which i cant seem to get around:
When the activex-control is called, it opens Acrobat Reader (as a separate window), and i dont want it to do that. If it has to, i atleast want to keep it minimized and/or closed afterwards.
Any ideas?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,139 Views)
Please post what you have did so for or just give a screenshot
(4,136 Views)
So far:
"print-test" uses my "print pdf" to write a .pdf and acrobat reader opens and never closes. If minimized it pops in front.
Qestit Systems
(4,132 Views)
Accepted by Yamaeda
After some more "fishing the sea" (searching the internet), i found out it's a Acrobat-bug. Apparently it happened to alot of VB-people using Acrobat 8 (guess what i'm using).
I tried installing version 9, and now it's perfectly silent, no Acrobat window opens at all.
However, i'm not sure which versions will be at the users computers, so i added a small hotfix. After printing, the Appliction does a "Bring to Front" so regardless if i get the Acrobat window or not, the VI will be in front and accessible.
/Y
Qestit Systems
(4,086 Views)
Excellent. Thanks for the update. Tossed you five (Sorry now kudos).  Smiley Wink
(4,082 Views)
