acquiring min and max values from continuous data values
I am relatively new to LabVIEW but am not sure how to acquire minimum and maximum values from a constantly changing data value.
The value changes continuously and I need to be able to log the minimum and maximum values that have been displayed during a period of time.
As I understand, the single data value needs to be inputted into a waveform, which can then be analysed as a graph. However I'm not sure how to do this!
If anyone has a relevant VI, I would be extremely grateful.
With many thanks
(3,075 Views)
a simple way to do this is to constant compare the present value with the low value and the high value.
if the current value is lower than the the min value, then the min value is changed to the current value.
Same for the max value.
Just initialize the min value with +infinity and the max value with -infinity.
(3,075 Views)
should read "constantly compare"
(3,075 Views)
Here's a simple lv 6i example
(3,075 Views)
many thanks - exactly what i need.
(3,075 Views)
