about web publishing after reset the compactRIO
I am using NI cRIO-9024, and I have install the software again by using the disc driver. I have installed all the components in the disc, but after this, both scan mode and fpga mode can work normally. Only when I am testing the web publishing function, it doesn't work. So is that any components is missing in the compactRIO?
(2,392 Views)
Hi 71316,
After installing all the software in the disc driver, then you should be able to publish your application. To begin, take a look at this Developer Zone tutorial http://zone.ni.com/devzone/cda/tut/p/id/4791 which shows how to correctly publish your application. In specific, make sure the LabVIEW Web Server is enabled to allow users access to the front panels on the Web.
If you are still having trouble after following the tutorial, please post back more details of your application. Is this a Real-Time application? What version of LV are you using? Are you working with an executable? What error messages do you get when you try to load your applicaiton on the web? List the drivers installed on the cRIO.
Hope this helps!
Aldo A
(2,367 Views)
thank you very much, problem solved.
it is about the cRIO driver version dismatch to my LabVIEW version,
I'm using LabVIEW 2010, and the cRIO version should be 3.5
(2,358 Views)
