about labview signal processing
Hello Sir, Myself Sanmati Kurkute
 I am Working on project-Fault detection of two stage reduction gearbox using vibration analysis techniques.
I have to perform some operations on raw signal obtained from accelerometer.
Following operations are to be performed
1.FFT
2.Morlet wavelet transform
3.time frequency domain averaging
4.plot of power density spectrum
Sir. can you send me screen shots of this processes. I will be very thankful to you for above.
(sir please help me as soon as possible , as my seminar is at 10am on 28th, till date I tried on it but could not find solution, hence contacting you.)
(3,081 Views)
Check the Advanced Signal Processing Tookit fot Morlet Wavelet Transform. Rest of the things you can find it in LabVIEW signal processing tookit. Posting question and asking for your Home work is considered Rude here. Please go through LabVIEW training materials and do search, you will get what you are expecting. Good luck
(3,074 Views)
