about control flir a700 thermovision camera
Hello
I 'm trying to control flir a700 with labview.(using port ETH/Poe) (using IMAQdx)
I found an example of Labview on the website of teledyne. "A400_A500_A700.zip"
The video comes out, but the communication is cut off irregularly or the image is not clean
Is there any way to solve this problem?
thank you
Sang-min Sim
(1,773 Views)
Hi ssabnim
There is an article which is giving a solution for this error. I suggest going through that article to solve this problem.
Regards)
_______
Best way to thank is to give Kudos / Mark as a solution.
(1,550 Views)
Thank you for your response.
The firmware update has already fixed the issue
have a good day!
(1,522 Views)
