LabVIEW Runtime Installation Not working
I am trying to install LabVIEW runtime. But it wont install. I dont know why. I have uploaded the pictures of the installation process where the problem can be seen. So the original is in german and I have used a online tool to translate the pictures into english. Just wanted to let you know. Thank you.
(2,180 Views)
Honestly, I don't really recognize those programs you're trying to install, but the final (3) message says you already have a more recent version installed.  Have you tried uninstalling it first?
I also noticed these are 64-bit versions.  Unless you REALLY have a good reason to use LabVIEW in 64-bit, you should stick to 32-bit.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,158 Views)
Why does it say NATIONAL INSTRUMENT?
 No S at the end of INSTRUMENT
(2,149 Views)
Check the already installed software's in the Machine  using NI License Manager to understand more on the available software before installing new one.
(2,124 Views)
As mentioned in the previous comments, you might have latest version of runtime installed on your machine. Open Ni MAX and check the installed software's.
 looks like image is a translated screenshot of installation,
bp
(2,075 Views)
