Showing results forĀ
Search instead forĀ
Did you mean:Ā
abc
Hi Joel,
Thanks for your message.
With the last code that I posted (flat sequence structure), the program runs well for the first time!
But when I stop it and hit run again, I get error: 200022. Please see screenshot attached.
Maybe it needs a reset on exit? I dont know how to do that.
Cheers,
Saif
Message 11 of 28
(1,930 Views)
@Vhha1972 wrote:
Hi Joel,
Cheers,
Saif
Never use the stop sign to abort a VI!  This results in no housekeeping being done.  Your task is most likely still open when you run it again.  Hence the error.
Bill
CLD
(Mid-Level minion.)
Message 12 of 28
(1,909 Views)
Hi Bill,
Your advice has been most useful!
When I use the proper stop button, I dont get that error - thanks šŸ™‚
Now, I will try the more complicated code. But I am hopeful that it will work since this one works.
Will keep you all posted.
Thanks again to all!
Saif
Message 13 of 28
(1,898 Views)
Hi Again,
The problem is actually not fully resolved.
I tried it a couple of times by using the preferred stop button as opposed to the abort button.
Again, it fails on the second start. Earlier, it worked a few times. But now it fails again.
Any more suggestions?
Cheers,
Saif
Message 14 of 28
(1,885 Views)
same error: 200022
Message 15 of 28
(1,884 Views)
@Vhha1972 wrote:
same error: 200022
I think if you aborted ONCE you will get that error until you shut LabVIEW all the way down then restart it.
Bill
CLD
(Mid-Level minion.)
Message 16 of 28
(1,878 Views)
Hi Bill,
I shut down everything, restarted my laptop, restarted Labview, then just used the preferred stop button. But it only works the first time.
Cheers,
Saif
Message 17 of 28
(1,873 Views)
@Vhha1972 wrote:
Hi Bill,
Cheers,
Saif
Drat.  I can't actually see your VI (I'm only at LV 7.1) so they were educated guesses.  I guess I will have to turn this over to someone who can actually see what you are doing.  Sorry šŸ˜ž
Bill
CLD
(Mid-Level minion.)
Message 18 of 28
(1,864 Views)
I am attaching my VI again. Its in V8.6.
Hope someone could help!
Saif
Message 19 of 28
(1,862 Views)
save with options --> save for previous --> 7.1 and I'll still be able to help.  šŸ˜‰
Bill
CLD
(Mid-Level minion.)
Message 20 of 28
(1,856 Views)
