a vocal comand
hello, i want to create a vocal comand for interface  of car ,so i need to create a database which contain words <<sound data>> ex:
"move" "start" "stop" "left" "right" ...
ps: i do my best to write in english ,be understandable.
(3,514 Views)
Hi Rikrak,
Speech recognition is a really complex task, some of the most efficient speech classifiers implement Machine Learning, Neural Networks and so on. I would recommend you to take a look at this example if you are willing to compare voice signals generated:
https://forums.ni.com/t5/Example-Code/Using-LabVIEW-for-Voice-Signal-Analysis/ta-p/3996192
But in my opinion, the best way to tackle this problem is by training a model with your voice instead of creating a database with "sound data". This example may be useful:
https://forums.ni.com/t5/Example-Code/Voice-Recognition-Data-Acquisition/ta-p/3529966
Hector Beristain
Application Engineer
Click on the golden star if this helped you.
Kudos are welcome 😉 marked solutions are awesome!
(3,459 Views)
Accepted by topic author rikrak
There is a program called LabVIEW speak someone made which let's you interact with LV by talking into a mic. If I were you I would see how that program solves this problem and see if that will work for you.
(3,454 Views)
Here is the LabVIEW speak documentation. But as I said, you need to train the model before using it. In my opinion, this one would be harder to adapt to your program.
http://forums.ni.com/t5/LabVIEW-APIs-Blog/LabVIEW-Speak-Programming-LV-through-voice-commands/ba-p/3...
(3,435 Views)
 it's  inteseresting  thank you for your helps
(3,404 Views)
