Example Code
Voice Recognition Data Acquisition
Code and Documents
Overview
This VI demonstrates how to use Windows Speech Recognition to control a data acquisition application
Description
The Speech API can be called from LabVIEW to create any speech recognition application, in this case, data acquisition. The Speech API is part of the .NET Framework which in most cases is already installed on computers running Windows XP or Vista OS or later. In general the API will automatically “listen” for key phrases, perform voice recognition analysis on the audio stream, and will also convert text to speech.
For more info visit:http://www.microsoft.com/speech/speech2007/default.mspx
Requirements
Software
  • LabVIEW 2012 (or compatible)
  • .Net Framework 3.5 (or compatible)
  • Speech API version 5.3 (or compatible)
Hardware
  • Microphone
1. Configure your Windows Speech Recognition and train your computer to your voice
2. Run this VI
3. Say loudly one the Phrases in the list (Check the block Diagram for more information)
4. Exit this VI
Additional Notes or References
Front panel of main application:
Block Diagram
For assistance with navigating the Speech API commands, check out Microsoft's MSDN site (http://msdn.microsoft.com/en-us/library/system.speech.recognition.aspx), where you can find to find lots of code snippets and descriptions of all the speech functions.
Comments
tarif
Member
Member
on
i am a mechatronics engineering and i have a task to control a motor completely by speech recognition .... and i tried to run your code but i didn't run because some files are missing ... so can you help me with that
tarif
Micael_
Active Participant
Active Participant
on
Hi all.
I tried this code, and after removing the missing VI, I still got an error : "The language for the grammar does not match the language of the speech recognizer.".
I guess it was due to the french version of XP I am using.
To fix the problem, I set the GrammarBuilder culture to "en-US" and the code is working fine now.
Hope this helps.
Micael.
Cordialement,
Micaël DA SILVA
ardee3949
Member
Member
on
It would be great if you upload the missing .vi ..
Micael_
Active Participant
Active Participant
on
Hi ardee,
You don't need the temperature VI to run the example. As it commects to hardware, it wouldn't work anyway.
All you have to do is just replacing it with the random number function and run the example to see how it works.
Cordialement,
Micaël DA SILVA
deepAg
Member
Member
on
Hello
I am attempting to do a similar project. I tried running ur VI, it is running without error but inputs from windows voice recog is not working with the program.
Ex: when i say start, it goes to windows start instead of controlling the vi.
Will be very thankfull, if u can reply asap.
NJKirchner
Active Participant
Active Participant
on
For reference, the .NET speech API has been neatly packaged up within the LVSpeak / GSpeak library available here
http://lavag.org/topic/15955-labview-speak-basic/
Please reply there or contact me directly if there are any challenges getting it up and running.
This should aid anyone just trying to get basic Speech detection integrated into LabVIEW
meriem1991
Member
Member
on
hi
some files are missing .can you upload the missing VI
luisalor
Member
Member
on
mohmdth120
Member
Member
on
hi >>>>>>
can you help me to upload my code to arduino (i use makerhub library):::::::::
and thanks
NJKirchner
Active Participant
Active Participant
on
Mohmdth,
I think you may have posted to the wrong forum.
shammer
Member
Member
on
I had issues getting Micael's code working. Apparently on my system (running Win7) I can't read the CultureInfo class (System.Globalization.CultureInfo).
I worked around it by reading the Culture from SpeechRecognizer then using that to set the culture of the newly-created GrammarBuilder:
SpeechRecognizer culture reading to set GrammarBuilder culture.pngSpeechRecognizer culture reading to set GrammarBuilder culture.png
Contributors
