a problem of array manipulating
Hi:
    I am sorry for wasting your time if this manipulation is a basic manipulation . I'm a newer to Labview and I have tried many methods, unfortunately it didn't work.
   There are two arrays that reference array and experiment array respectively. assuming they are
Array(R)    0    0    5    5    5    5    0    0    0    5      5      5       0     5
Array(E)    1    2    3    4    5    6    7    8    9    10    11    12    13    14
   How can I get some new subarrays from Array(E) which elements corresponding with the element valued 5 in the Array(R). for this instance, the new subarrays here are:
Array(E1)     3    4    5    6
Array(E2)    10    11    12
Array(E3)    14
帖子被Fuyu在 05-13-2010 11:05 PM
时编辑过了
Message 1 of 11
(4,634 Views)
Accepted by topic author Fuyu
Hi!
Try this and let me know 🙂
Message 2 of 11
(4,608 Views)
Like this?
Message 3 of 11
(4,606 Views)
Hi FUYU,
  Check this program...
Thanks and regards,
srikrishnaNF
Srikrishna
Message 4 of 11
(4,595 Views)
Quoting from the previous replies
Like this
In five years when someone new is looking at this thread, they will have no clue as to what you have suggested and may require an old version of LV to even look at what you have posted.
Please add some words that describe what is in the attached VIs or even better, post an image of your code.
Please don't take this message as if I am trashing your posts. Far from it! I am just trying to macke sure your contributions stand the test of time rather fading off into the dust-bin of obsolete software.
Your brother in wire,
Ben
Message 5 of 11
(4,560 Views)
Hi MarcoMauri ,
    Appreciating , it meets my needs perfectly.
帖子被Fuyu在 05-15-2010 05:41 AM
时编辑过了
Message 6 of 11
(4,541 Views)
hi muks ,
I'm sorry it doesn't meet my need, thank you anyway.
帖子被Fuyu在 05-15-2010 05:46 AM
时编辑过了
Message 7 of 11
(4,536 Views)
hi srikrishnaNF ,
I'm sorry it doesn't meet my needs, thank you anyway.
Message 8 of 11
(4,533 Views)
Like this
Ben
Point taken...:smileywink:
Message 9 of 11
(4,495 Views)
Like this
Ben
Thanks Ben. I join with MUKS here :smileywink:
Message 10 of 11
(4,486 Views)
