a problem about the SubVI application
Hellow!
Attached is a simple example about using subvi,i want to use input data.vi as a control panel,so that when i run main.vi,the data from input data.vi will show in main.vi,i have made two output teminal for the input data.vi,but why i can not connect the two teminal from input data.vi to the indicator in main.vi? thanks!
Message Edited by happybird on 06-09-2005 10:24 PM
(2,434 Views)
You cannot connect an input of a subVI to a indicator, you need to turn the two controls on the "input data.vi" into indicators.
Now their connectors automatically turn into outputs that you can connect to your indicators on the main.vi.
(2,424 Views)
