Hi, I want to plot the time-domain signal on the exactly on the way it leaves the signal generator, frequency, amplitude etc... Im using PXI-5660. Is it possible? Thanks, Valerio Nobre
What software are you using? I am assuming you are using LabVIEW but which version? Whichever version you have there should be example programs that installed with your specific driver...they can be found at HELP>>Find Examples. I don't have your specific driver loaded so I will not have the examples but if you do not see anything that helps you reply and let me know what version of LV you are using.
