a problem about losting frames when using PCIE1430
  I use a NI pcie1430 card and silicon imaging 1300MH_CL camera .when in MAX it appears a frame rate 300 fps。 But when I use the example LL Ring the example finder with a write image module , it saved 270 images one second in the disk, So ,what is the problem ,how to solve it .
Thank you
(2,715 Views)
(2,711 Views)
