pcie1430 lost frames
  I use a NI pcie1430 card and silicon imaging 1300MH_CL camera .when in MAX it appears a frame rate 300 fps。 But when I use the example LL Ring the example finder with a write image module , it saved 270 images in the disk, it seems the write module affect the grab,
So ,what is the problem ,how to solve it .
Thank you
(3,024 Views)
 What does the "write image module" do in your code? Maybe you could benchmark this module to see whether this is really the cause of low frame rate. If so, using another loop for write module should ease the problem (File->New...->From Template->Producer/Consumer Design Pattern (Data) should be a good example).
(3,001 Views)
thanks fot the reply I solved the problem days agao
(2,999 Views)
