10-06-2010 12:23 PM
I am having issues running my VI using Zoom FFT and plotting the Real Values of the FRF. I generated a signal with noise and am attempting to focus on the region between 0 and 500 with the most amount of lines possible (is there a max number of lines that LabView can preform?). When I attempt to graph the real values of the FRF I get a blank graph. I attempted to output the Y values of the real portion of the FRF in an array and get all zeros. Can someone please advise?
10-07-2010 06:57 PM
Hi Hova,
I ran the VI you posted and plotted data to the Real Part of FRF graph without any issue. What zoom settings are you using?
Aaron P
Applications Engineer
10-11-2010 11:56 PM
Ha really? Could there be an issue with the version I am running? Version 8.2? Whenever The program runs nothing is plotted except the original graph.
hova
10-12-2010 06:18 PM
Hi Hova,
Have you seen this on multiple VIs or just with this VI? If it's just this VI, try copying the block diagram from this VI to a fresh VI and running it.
Aaron P
10-13-2010 12:12 PM
I just tried copying and pasting the block diagram into a new VI and it still doesn't work. Any other suggestions??
