Zero padded numeric format
I am trying to format a floating point number to a zero padded string.
19.1 =>   0019.1
-19.3 =>   -019.3
Neither the Format Value or the Number to Fractional String seem to let me get to the zero padded string I need.
Suggestions?
(4,692 Views)
Number to Fractional String has a Width input. Set this however you would like and then use Search and Replace String function to replace all spaces with zeroes. If there's a negative number, you'll have to move it to the front after the string conversion.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,685 Views)
Accepted by topic author SunshineDesign
Format into String with the right format string code.
(4,679 Views)
