Zero padded numeric format
I am trying to format a floating point number to a zero padded string.
19.1 =>   0019.1
-19.3 =>   -019.3
Neither the Format Value or the Number to Fractional String seem to let me get to the zero padded string I need.
Suggestions?
(4,532 Views)
Number to Fractional String has a Width input. Set this however you would like and then use Search and Replace String function to replace all spaces with zeroes. If there's a negative number, you'll have to move it to the front after the string conversion.
Cheers
(4,525 Views)
Accepted by SunshineDesign
Format into String with the right format string code.
(4,519 Views)
