Yahtzee Game
Updated the code with RavensFan's comments.
You need to set the Keep array to default to 5 falses.  It currently defauts to an emtpy array, which will cause no rolling to happen.
Something you should do is add a counter to see how many rolls have been performed.  Then you can have the VI stop on its own after the third roll.  Hint: you will need another shift register.
Message 11 of 13
(1,463 Views)
Okay so Im currently working on this project as well for my class but I have absolutely no idea where to find the KeepTF and RollTF things. I dont even know what those are called. My professor isnt very good. Please help.
Message 12 of 13
(893 Views)
Hi Cuda,
as you surely took the free beginner courses offered by NI you should know:
- those are boolean "things" from their green color
- those are controls as they are data sources
- those are arrays from the thickness of the wires coming out of them
- atleast "Keep" is a 1D array as the FOR loop autoindexes the wire to scalar values
What else do you need to know?
Message 13 of 13
(887 Views)
