05-06-2017 03:23 AM
I do not have the xilinx compilation tool installed with labview fpga. I have tried searching the NI website to find a suitable version for the compilation tool but haven't been able to.
I am using NI cRIO - 9014, can anybody tell a suitable version of xilinx compilation tool that is compatible with my cRIO?
Below is the image of the error I was getting while deploying
Solved! Go to Solution.
05-06-2017 03:23 AM
05-06-2017
07:22 AM
- last edited on
11-17-2024
01:48 PM
by
Content Cleaner
This is a Real-Time controller and does not have an FPGA. The FPGA is in the reconfigurable embedded chassis.
On https://www.ni.com/docs/en-US/bundle/crio-9012-9014-user-manual/resource/crio-9012-9014-user-manual.... see page 5 item 4. Which part do you have for that?
Once you have that part, check here:
05-06-2017 07:59 AM - edited 05-06-2017 07:59 AM
I have four different modules installed on my chassis that are based on fpga. I wouldn't have been able to design a VI that includes fpga i/o modules and then got the error that states compilation tool is not installed.
Anyways, I found out that the problem was that LabVIEW FPGA module is not compatible with windows 10 and that's why Xilinx Compilation tool was not installed on my system. So, I have to use their cloud compiler service in order to run my code.
05-06-2017 08:02 AM
Great to hear. There should be an additional item which actually contains the FPGA.
Cloud compile is definitely a good option. I use this when I do not have the Xilinx tools installed for a particular FPGA.
