XY graph
Can someone show me how to fix this?
Krispiekream
Message 1 of 10
(5,488 Views)
I need the ORANGE "Pot Graph" indicator instead of the purple. how would I change the right block diagram to work?Capture.PNGCapture.PNG
Krispiekream
Message 2 of 10
(5,482 Views)
Attach and post your actual code, not pictures of code.
=== Engineer Ambiguously ===
Message 3 of 10
(5,469 Views)
Well, the purple is an array of clusters while the orange is just a 2D array with lots of duplicate information.
To create the orange from the purple, just autoindex on a FOR loop , unbundle, build, and concatenate. Should be trivial.
Message 4 of 10
(5,466 Views)
sorry. here you go.
thanks for your help
Krispiekream
Message 5 of 10
(5,448 Views)
how do I build it in a 2d array vs. bundling it to a cluster and then unbundle it.
it seems redundant.
Krispiekream
Message 6 of 10
(5,438 Views)
Accepted by topic author krispiekream
There are missing subVIs.
Your ramp generation seems a bit elaborate. Compare here:
To convert the current array of clusters (xy graph data) to a 2D array with the same information according to your old code, just do something like this:
(Of course this "solution" is specific to your data and makes certain assumptions. It might give undesired results, e.g. if the various plots have a different number of points)
Message 7 of 10
(5,435 Views)
I think I got it.
One last question.
Can you show me how get rid of green line on graph?
Krispiekream
Message 8 of 10
(5,417 Views)
These are your X-values. If you don't want them, don't include them in the 2D array!
Message 9 of 10
(5,415 Views)
Awesome!!!
That does the trick!!
THANK YOU SO MUCH!
Krispiekream
Message 10 of 10
(5,410 Views)
