annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
XY graph - point text
is possible to draw in XY Graph each point with coordinates like on attached picture(but this is only photomontage). On picture is standard XY Graph, with "Fill Base line to zero", but this is not important. Important is how to equip each point with text label like in Excel (picture 2).
Does anybody know the solution?
LV 2011, Win7
Messaggio 1 di 4
3.471Visualizzazioni
One method is to use blank cursors with labels to add text to points.  Mads gives a good example of this here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=64788
2006 Ultimate LabVIEW G-eek.
Messaggio 2 di 4
3.461Visualizzazioni
If you have LabVIEW 8.0, you can use an Graph Annotation directly. Makes things much easier! 🙂
Messaggio 3 di 4
3.453Visualizzazioni
Unfortunately I haven't got LW 8.0 😞 only 7.1, I'll try the way from the mentioned thread.
Thanks a lot
LV 2011, Win7
Messaggio 4 di 4
3.435Visualizzazioni
