XY graph multiplot
I have some questions about XY graph. Please kindly see the block diagram attached.
Basically, at each iteration, the program will generate one set of X-Y data and I wanted to plot all sets of X-Y data inside one graph. If I plot the function 'X-Y' graph inside the for loop, it will only show one plot, but if I put the 'X-Y' graph outside the graph, it will show all the plots at a time at the end. Is there a way that it will show plot one by one?
the second quesions is I want to show the plot legend as the applied bias, How can I control the plot legend? I am using Labview 2010. I right clicked the X-Y graph, then go to Create--> property node, I didn't see a property of plot legend.
Joyce
Message 1 of 10
(7,879 Views)
Hi Joycezh
Yes you can, try using shift registers to keep the data and plot it again, here is an example that you can find in this link.
https://decibel.ni.com/content/docs/DOC-16243
Propery->legend->plots shown , here you can define how many plot do you want to show.
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
Message 2 of 10
(7,874 Views)
Hi Joycezh
If you cant find that property node explained in this link http://zone.ni.com/reference/en-XX/help/371653B-01/lvprop/wfmgrph_lgndplots_shwn/
, try with LegNumRows with the LegVis property Node enable
Jaime Peña
www.ni.com/soporte
Message 3 of 10
(7,867 Views)
All you need is drop the xy graph from the express palette. It includes the build xy graph express VI. To retain a history, configure it to retain data between calls.
You can configure all graph properties via property nodes (axis: xo, dx, axis label, etc; plot: label, etc.). This needs to be done only once, of course and not over and over in a loop. To change the plot legend, select property "plot...plot name"
Please attach your VI to make it easier to show the best modifications.
Message 4 of 10
(7,849 Views)
I changed my program to this, however, it can only show 2 curves, why?
Joyce
Message 5 of 10
(7,827 Views)
Hi, Altenbach,
Here is my VI. I am still lost on how to retain a history...
Joyce
Message 6 of 10
(7,818 Views)
You need to put the array of accumulated plots into the shift register, not only the new plot.
Here's a quick revision (Also the legend property needs to be set only once before the loop).
Message 7 of 10
(7,811 Views)
Thanks, Altenbach, now it shows all the plots in the graph.
However, the legend is not correct, please see the attached. The legend "-0.70000' is actaully the name for the last plot (the blue curve).
Joyce
Message 8 of 10
(7,799 Views)
Accepted by Joycezh
property nodes execute to to bottom. You need to set the active plot before setting the legend. See attached.
Message 9 of 10
(7,794 Views)
Thanks a lot! It works!
Joyce
Message 10 of 10
(7,787 Views)
