XY graph - clear programatically
I know how to programatically clear a chart but am having trouble doing the same with an XY graph. I am assuming it is possible, but cannot find the options I am familiar with. How do I go about doing this?
Thank you!
(3,133 Views)
Try wiring an empty constant to it.
Right-click on the terminal and select "Create Constant" then wire the constant to the terminal when a clear button is pressed on the front panel using a case structure.
I modified the example I posted to one of your earlier questions to work with an XY graph, see attached.
Brian
(3,133 Views)
Hi Ellie,
In the examples\general\graphs folder you should find a vi called Graph Control.vi. This should help you solve your clear XY graph.
Regards
Ray Farmer
Regards
Ray Farmer
(3,133 Views)
