XY Graphs with X values from 1d Array, and Y values from 2d Array
I have a 1D array of times t, and a 2d array where each column is a function f1(t), f2(t), f3(t), f4(t).
How do I generate the cluster needed as an input to the Graph Indicator from these two things to plot f1,f2,f3,f4 on the same graph? or ever have each on their own graph?
(6,991 Views)
Hi math,
use an autoindexing FOR loop to index your Y 1D data from your 2D array. In the loop you build a cluster of X and Y 1D array, after the autoindexing output tunnel you will have an array of plots for your XY graph…
(6,986 Views)
What does yours look like? Each time I try to create it I get an error that my dimensions are wrong
(6,975 Views)
Accepted by ijustlovemath
Hi math,
as I told you:
(6,969 Views)
I managed to make it work by doing this:
That subVI just takes the 2d array and outputs a reshaped 1d array from the column vector given by the other input.
Final question, this thing will be part of a VI that runs once every iteration. Is there any way to "concatenate" the graphs of each iteration to show an overall graph?
(6,926 Views)
Also, the reason for using that subVI instead of just autoindexing is that autoindexing a 2d spits out rows, when I wanted columns. An alternate solution would be to transpose the solutions array and just use autoindexing.
(6,916 Views)
Hi math,
Yes, that's the correct order of things in a 2D array …
When you have measurement data, e.g. from DAQmxRead, you get your data row-wise!
Yes, that's the (most probably) more efficient solution…
(6,847 Views)
