XY Graph
I am trying to plot 2 VI curves onto one graph.  These are read from a spread sheet.  I can successfully read in both curves but they won't appear on the graph until I have read both in therefore I can't display only one.  I've spent near enough a whole day trying to solve this problem.  Is there a way to get only one curve dsiplayed.
Matt.
Code and severl sample documents which are being read in are attached below.
(3,302 Views)
Accepted by topic author gilgad2000
That VI does not make any sense. You should not use two separate event structures and you should not use an event structure without a while loop. With a single event structure and a couple of shift registers, you should be able to do what yuo want. Try the attached code. Since you did not attach any text files, I did not test it.
(3,299 Views)
Thanks for the help.  Still new to lab view so havn't got used to efficient coding yet.
Matt.
(3,271 Views)
