XY Graph plot legend
how do remove the plot legend's black frame?
Message 1 of 10
(3,298 Views)
It seems you xy graph is already quite customized and I can't really tell from which palette you started. (most styles don't even have that black frame and it is not obvious from a simple picture how you made it)
Typically you can color almost anything, and you can make that frame transparent. Once you attach a simple VI containing your graph, I can play around to see what's the best solution. You might not even need to use the control editor.
Make sure to use "save for previous" (e.g. 2019) before attaching.
Message 2 of 10
(3,280 Views)
Paint it transparent.
Certified LabVIEW Architect
Message 3 of 10
(3,277 Views)
Sorry, it's my fault. I got this picture from Export simplified image.
Thanks for your response.
Because I need the clear plot legend to put on my paper.
So I just want to know how to remove the black frame or change the color to transparent.
Message 4 of 10
(3,249 Views)
How did you do that?
Because I changed it to transparent color, the original line will become transparent.
Could you tell me the details? Thanks.
Message 5 of 10
(3,247 Views)
What is "it"? What is "the original line"?
Message 6 of 10
(3,235 Views)
When I press the transparent, it only changes the color of the line, but I still can't remove the frame.
Message 7 of 10
(3,230 Views)
Accepted by devinchao
like in the attached clip
Message 8 of 10
(3,210 Views)
I found the tools palette in View, that I can change the color just like your methods.
Thank you!!
Message 9 of 10
(3,200 Views)
Thank you!!
To get the tools palette, all you need is "<shift>-right-click" on the background. 😄
Message 10 of 10
(3,170 Views)
