XNode
Message 1 of 18
(5,353 Views)
It might be protected, goto XNode properties>Protection and check the protection level. If it is password protected then you amy need to enter password to keep it unlocked.
Message 2 of 18
(5,344 Views)
Message 3 of 18
(5,338 Views)
My bad. You are trying to open a library which is password protected and can be open by NI only as it shows in the message. Why do you want to open the library anyway? BTW its not your XNode 😛
Message 4 of 18
(5,283 Views)
Thank you! But this XNode below has no password,but it's locked. Can you open it in your computer?
Message 5 of 18
(5,279 Views)
Hi enen,
as the error message says: You don't have the proper license to edit that XNode.
Me neither: I can load/open the files, but can't edit the XNode…
Message 6 of 18
(5,253 Views)
XNodes are super secret and are just in general are for NI purposes only.  You have to have a special NI-only license in order to edit them inside of LabVIEW.  But if you head over to LAVA, there is a good discussion on XNodes.
Message 7 of 18
(5,243 Views)
But why others on the Internet claim that thay can create XNodes? It isn't top secret. Is that I didn't active something?
Message 8 of 18
(5,233 Views)
You can, you just can't edit  it in LabVIEW.  Head over to LAVA and do a search and you will find instructions.
Message 9 of 18
(5,180 Views)
Should I active LabVIEW on-line?
Message 10 of 18
(5,114 Views)
