XML report generation with Stylesheet
Hi all,
I am creating a LabVIEW code which would be generating a XML report. Is there any way we can import this report into a xml stylesheet programatically using LabVIEW and open the report automatically after the code has been generated?
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 8
(4,350 Views)
Hi Parag D,
you don't need to import the report into a stylesheet, you only have to insert a link to your stylesheet into the report.
it should be something like this:
<?xml version="1.0" encoding="ISO-8859-1" ?> <?xml-stylesheet type="text/xsl" href="./yourstylesheetname.xsl"?>
You can open your report with a browser. You can use the "Open URL in Default Browser" function for it.
Mike
Message 2 of 8
(4,347 Views)
I tried the same before, but when I opened the file in internet explorer, it would show only the script rather than the report. I used Tesstand stylesheet, just for trial. I can see the link referring to that stylesheet in the browser.
-FraggerFox!
Message 3 of 8
(4,335 Views)
Hi Parag D,
can you upload an example report and your stylesheet. For me it works like i said.
Mike
Message 4 of 8
(4,333 Views)
Hi Mike,
Here are stylesheets taken from teststand. I tried using one of them by a simple VI having some String controls like Name, Age, Address etc. and logging it to an xml file using this stylesheet. Is there any format or something I am missing?
If you have any sample VI for me, it would be of great help if you attach it.
I am using LV 8.2
Message Edited by Parag D on 08-25-2009 03:58 PM
-FraggerFox!
Message 5 of 8
(4,324 Views)
Hi Parag D,
where is your report? It should be a xml file.
Mike
Message 6 of 8
(4,316 Views)
Hi Mike,
I am generating xml report through JKI Easy XML toolkit (Write XML VI) which would be saving any data input to it in .xml format.
My question is how would I import this generated report into a stylesheet, programtically?
(I wired the stylesheet input of JKI Write XML VI with one teststand stylesheet but it didnt work out as expected)
-FraggerFox!
Message 7 of 8
(4,309 Views)
Hi Parag D,
i only insert the link to the stylesheet into the xml file. I do this at the beginning of the xml file. If you then load the xml file, it should also use the stylesheet to present your data.
Mike
Message 8 of 8
(4,305 Views)
