Writing a sample beyond the final sample generated
Hi everyone,
I aimed to generated sinusoidal waves with NI 9264 and change the place where to give the sinusoidal wave with a case structure. But when I run the VI a got the following error:
Error: “Attempted to write a sample beyond the final sample generated. The generation has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample generated. The final sample generated can be determined by querying the total samples generated after a generation has stopped.”
I'm trying to take continuos samples and stop taking samples when I click the stop button of the loop. But when the case changes, it gives the error on 'earese the previous task' function. That am I doing wrong? I'm trying to fix it for almost a week.
In addition to that when I check the wave with the oscilloscope, I saw that I couldn't achieve to generate a continuos wave but an interrupted one. I am adding an image of the oscilloscope screen. When I increase the sample rate on NI MAX it gets closer to a sin wave but I want a frequency around 100 Hz not 10k Hz. If someone can also help with this problem, I would be glad.
(1,439 Views)
You seem to be using a global task and I'd guess that you set it up for Finite sampling.
Take a closer look at the shipping examples for continuous AO voltage.  Notice that data is written to the task before calling DAQmx Start to start it explicitly.   The example lets the task run in regeneration mode -- whatever was written originally keeps regenerating.  If you define your sine wave over an integer # of cycles, that might work for you too.
Note that you *can* write new data to the task inside the loop if you choose, but doing so exactly right takes more care than simply relying on regeneration -- assuming your app wants a repeating, unchanging sine wave.
-Kevin P
(1,396 Views)
